SA1's avatar
SA1
Tutor
Jun 08, 2020
XR500 Firmware Downgrade to solve internet drop outs
Hello I have downgraded the XR500 FW to solve internet drop outs (to v2.3.2.22). Is it reasonable to run this or should I be trying a re-upgrade to v56?   I had frequent drop outs to VDSL with my...
  • Netduma-Fraser's avatar
    Jun 12, 2020
    .56 has many more vulnerability fixes in it than .22 will so in that regard it's a much safer firmware to have installed. They basically do the same thing of passing traffic straight through to the router. I'd suggest doing the DMZ method and disabling the QoS on the modem as you've suggested, if two devices are manipulating the packets then it could cause issues as you've experienced.
