LevelUpLiam24
Mar 16, 2020Apprentice
XR500 Firmware issue
Hey all, This is the second time I've encountered this issue, the odd thing is this time I can't resolve it myself. I'm getting the dreaded "DumaOS not loaded yet" message. I went to rout...
- Mar 17, 2020The easiest thing to do would be a factory reset as that should resolve it immediately, does that work?
Netduma-Fraser
Mar 17, 2020NetDuma Partner
LevelUpLiam24
Mar 17, 2020Apprentice
That did the trick! Thank you for the response.
It's a blessing that I had backed up my settings only a week or so ago! Must have preemptively had known lol. So a reset, update, and then a settings restore solved the issue.
Honestly, it would only be more complicated setting everything back up due to the fact Verizon requires you to retain their router to keep the TV guide data working.
Much appreciated!
Much appreciated!
