KurtMayer
Mar 27, 2020Aspirant
XR500 Firmware Update Stuck
Hello, I have a XR500 Nighthawk Router running with firmware V2.3.2.22 (since last year with no problems). After experiencing some odd connectivity issues the past few days I decided to see if th...
KurtMayer
Update: took a chance and rebooted the router. Came back up normally -- but not updated. Still at V2.3.2.22. So I took a backup of the Configuration settings (which I should have done earlier), and downloaded the firmware image for V2.3.2.56.
Using the DumaOS dashboard, I browsed for and applied the flash image file. Came back up running V2.3.2.56.
My only issue with the update is that I get a 'Script Error' for one of the display windows in the 'Dashboard'. No other information about the error other than a button stating that -- and a blank window in the 'Dashboard'.
Netduma-Fraser
Mar 31, 2020NetDuma Partner
After a firmware update it is recommended to do a factory reset to ensure that no issues carry over from previous firmware and it starts fresh on that version. I would suggest doing that as it should resolve this issue as well.
