jhilgendorf
Apr 16, 2021Aspirant
XR500 Firmware update v.2.3.2.114 Packet Loss
I am having an issue with packet loss ever since i updated my firmware to v.2.3.2.114. I have restarted and factory reset the router multiple times to try and resolve the issue with no luck. The...
jhilgendorf
Netduma-Fraser
Apr 16, 2021NetDuma Partner
You're not experiencing packet loss don't worry, if you were then it would appear on the bottom graph so you can ignore that
