JoonDerg
Mar 01, 2018Tutor
XR500 Firmware Update
Having an issue with firmware. I go to System Information. It says Firmware Version V2.1.0.6. I go to Settings -> Administration -> Firmware Update -> Check I get: No new firmware version...
- Mar 02, 2018
Might I suggest to the OP. to use FF and be sure to clear web browser cache prior to updating router FW.
JoonDerg
Mar 02, 2018Tutor
OK, I was able to upgrade in Firefox. I had previously used Chrome.
In Firefox the Check for firmware update did not work again, but I got the firmware file and uploaded it and it didn't give the error message again and it updated it and restarted it. So I am on that latest firmware now. Thanks!
- Netduma-FraserMar 02, 2018NetDuma PartnerGreat to hear you were able to update successfully! Let us know if you see that again when upgrading to the next firmware release.
- JoonDergMar 02, 2018Tutor
OK, I will. Thank you!
