JoonDerg
Mar 01, 2018Tutor
XR500 Firmware Update
Having an issue with firmware. I go to System Information. It says Firmware Version V2.1.0.6. I go to Settings -> Administration -> Firmware Update -> Check I get: No new firmware version...
- Mar 02, 2018
Might I suggest to the OP. to use FF and be sure to clear web browser cache prior to updating router FW.
Netduma-Fraser
Mar 02, 2018NetDuma Partner
Great to hear you were able to update successfully! Let us know if you see that again when upgrading to the next firmware release.
JoonDerg
Mar 02, 2018Tutor
OK, I will. Thank you!
