RA1NS's avatar
RA1NS
Guide
Feb 26, 2019
Xr500 firmware
Hi, I am just wondering when we can expect a new firmware version? I am running v2.3.2.40. I am experiencing issues with 'qos' as well as 'geo filtering'. I have also read about a lot of issues others are having within the community. So I'm hoping that someone can provide some info on the next firmware. Thanks
  • We can't give out any timelines for firmware updates unfortunately, that's down to Netgear. What are the issues you're experiencing?
  • FURRYe38's avatar
    NG doesn't post when future FW updates for forthcoming. You'll have to keep an eye on the download support site or here in the forums when it's mentioned it's been released.
    Has your router worked before upgrading to v40?
    Have you factory reset the router and setup from scratch after v40 was applied and tested?
    Might try reverting back to prior working version of FW if that worked for you.
    What issues are you experiencing with the router? Please be specific and detailed if possible.
