kai-melb
Feb 13, 2021Follower
XR500 firmware
Hi all Is there an anticipated date for the beta XR500 firmware + DumaOS upgrade to be finalised and released? I purchased the XR500 just over 2 years ago and its been sitting gathering dust ...
Netduma-Fraser
Feb 13, 2021NetDuma Partner
There is no set date because it really depends on how well the beta goes. Saying that, the latest beta update is pretty stable and does include fixes that help with the DHCP issue, I'd recommend giving it a try. Would suggest a factory reset after upgrade. https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
