JAS107
Dec 08, 2018Tutor
XR500 fixed up to CCTV Dvr
Hi, new too forum Recently bought XR500 pro gaming router & trying to setup fixed up camera DVR Set fixed IP in LAN settings which auto set a fixed ip to device Port forwarded my usual 8080 port bu...
- Dec 11, 2018I'd put the camera in the DMZ of the XR500 and enable access from the WAN and that should do it.
Dec 10, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
JAS107
Dec 11, 2018Tutor
Hi thanks for message
I will check this out tonight and update when successful
Thanks again
