JAS107
Dec 08, 2018Tutor
XR500 fixed up to CCTV Dvr
Hi, new too forum Recently bought XR500 pro gaming router & trying to setup fixed up camera DVR Set fixed IP in LAN settings which auto set a fixed ip to device Port forwarded my usual 8080 port bu...
- Dec 11, 2018I'd put the camera in the DMZ of the XR500 and enable access from the WAN and that should do it.
Netduma_Jack
Dec 11, 2018NetDuma Partner
What do you mean by 'as soon as I set to 4G'? I assume you mean on the camera. If it's working on the XR500 when connected via LAN, then is this not a question for the camera manufacturer if it's not working after going to 4G?
Apologies if I have misunderstood.
JAS107
Dec 11, 2018Tutor
Ok, so:
On Netgear XR500
LAN Setup I reserved address to CCTV ip 10.0.0.1
Advanced settings/ port forwarding opened ports 554 & 8080 (External & internal)
Port Triggering CCTV :8080
On my BThub6
On Ethernet TAB Port 1 (connection devices) I used the XR500 to replace ip-address from my prior connection (i.e. the ip & mac address of Router)
To correct my own thought train earlier, I did open port on XR500 as the intentional 80 port that I always have used prior confilcted with another system on XR500 so chose the 8080
I do not think this is the correct way but is works, I would prefer clarification or another way to do it correctly (if this is not correct that is?) I had connected support by live chat the evening prior but could not help wih issue (they could but required $199 for years subscript for a brand new product?)
I confirm it does work correctly on both new iphones and SDK- hikvisions own software DVR Player https://www.hikvision.com/en/Support/Downloads/SDK
I could not connect via firefox or IE (thought firefox would break through with add-in but no joy.................
