BlxRayden
Dec 15, 2021Aspirant
XR500 Flashing White Light Corrupted fw
Hi all, I have an issue with my XR500. Got it as a second hand, when it arrived it had amber orange light flashing so i decided to reset it. After i reset the router i started to get the flashing wh...
Dec 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Did you try nmrpflash?
https://github.com/jclehner/nmrpflash
Try a different power supply with same specs.
If nothing works then the router maybe a bust.
Thank you.
- BlxRaydenDec 15, 2021Aspirant
Yea i did try the nmrpflash (Cmd level), but i think it has a filesize limit of 29-30 mb, the xr500 update is 37mb so i get a server timeout error with that.
And thanks for the suggestion, any way to move this post to where it actually supposed to be or should i delete this one and post it there?
Thanks
- FURRYe38Dec 15, 2021Guru - Experienced User
Will get moved. :smileywink:
