BlxRayden
Dec 15, 2021Aspirant
XR500 Flashing White Light Corrupted fw
Hi all, I have an issue with my XR500. Got it as a second hand, when it arrived it had amber orange light flashing so i decided to reset it. After i reset the router i started to get the flashing wh...
BlxRayden
Yea i did try the nmrpflash (Cmd level), but i think it has a filesize limit of 29-30 mb, the xr500 update is 37mb so i get a server timeout error with that.
And thanks for the suggestion, any way to move this post to where it actually supposed to be or should i delete this one and post it there?
Thanks
Dec 15, 2021Guru - Experienced User
Will get moved. :smileywink:
