BlxRayden
Dec 15, 2021Aspirant
XR500 Flashing White Light Corrupted fw
Hi all, I have an issue with my XR500. Got it as a second hand, when it arrived it had amber orange light flashing so i decided to reset it. After i reset the router i started to get the flashing wh...
Netduma-Fraser
Dec 16, 2021NetDuma Partner
Don't do a 30-30-30 reset as that can damage the router. Unplug it from power for 10 minutes, plug in, wait 2 minutes, hold the reset button for 30 seconds, release, wait 2 minutes then see if you can access
BlxRayden
Dec 16, 2021Aspirant
I did that as well. But no success. All i'm getting is the blinking white power light.
- Netduma-FraserDec 17, 2021NetDuma PartnerIf you've never been able to access it and TFTP isn't working then I would take it up with the seller and get a refund
