Bergli
Jan 10, 2021Follower
XR500 fluctuation
Why does the send, recive and the tick rate fluctuate so much?
Netduma-Fraser
Jan 11, 2021NetDuma Partner
It is dependent on the game, it's nothing you can influence on your side. If you feel it fluctuates too much and that is affecting your gameplay then I would suggest forcing a different server.
