jesusm07
May 17, 2018Guide
XR500 FRIENDS ON MY GEO-FILTER ALLOWED LIST NOT ABLE TO JOIN ME
I have the NIghthawks XR500 router. When I go into my Geo-Filter I have a certain distance set for my radius (1000 miles) that I like to keep it at and have it in filtering mode. I have a few friends...
- May 17, 2018Put it into Spectating Mode make sure there is nothing on the Geo-Filter. Then invite them to a party or game lobby, whatever shows up will be them, ping them and then add them. You should then be able to change to Filtering Mode and be able to connect with them.
jesusm07
May 17, 2018Guide
I just tested it with a friend of mine that is in my allowed list and does have a Static public IP. He was not able to join me. He tried twice and was only able to finally join only after I increased the radius. Once I did that I was able to reduce it and has was he was able to remain in my lobby. Not only that he lives in AZ but he is shown to live in OK. Same as another friend of mine on my allowed list he lives in CA but shows him to be located in OK as well.
Netduma-Fraser
May 17, 2018NetDuma Partner
- jesusm07May 17, 2018GuideI've tried that before. Instead of increasing the geo radius change the setting from filtering to spectating mode. Then select "allow" when they appear. The moment they have joined and I change it back to filtering mode they get disconnected. The only way they have been able remain connected is by increasing my geo-filter radius, wait for them to join ...then I can reduce it again.
- Netduma-FraserMay 18, 2018NetDuma PartnerIf they are already connected to you and showing on the map then changing to Filtering Mode would not do that. We specifically made sure of that for Anti-Cheat purposes. Can you record a video of what is happening please.
- jesusm07May 19, 2018Guide
ok So I finally got it working. Yes they were getting kicked out even after I did everything I mentioned on my prior posts.The one thing I didn't do before was ping them first. So I did what you said which is put in spectating mode, PING them, invite them and then added them which is what you told me to do. I just didn't realized and know how to ping anybody up until this last time I signed on. Before switching from spectating to filtering did kick them out if they were not within my radius but not this last time. The only thing I did different was ping them first before I added them to my allowed list. That worked. Now they can join me with no problem and stay connected regardless if I switch from spectating to filtering or wether they are within my radius or not ...they stay connected to me. Thank you for helping me find a solution.
