Klys's avatar
Klys
Tutor
Oct 25, 2019
XR500 FTP, no download permit
I have a USB-drive connected to the router and it worked fine aprox a year ago. But after some update I can only connect and upload files via FTP, not download anything.
See my settings in attached picture.
Regards
  • Klys's avatar
    Klys
    Oct 28, 2019
    I finally solved this problem.
    Downgrading the firmware didn't help.
    I had to change the "Write Access" on my USB drive to "All - no password" to be able to download files from the drive via FTP.
    When I have admin access only it does not allow me to download anything, only upload.
    See attached picture.
    Regards.
  • Forgot to mention firmware:
    V2.3.2.56
    DumaOs Name: A7Legit
    • Netduma_Alex's avatar
      Netduma_Alex
      NetDuma Partner
      I'm not sure why this is happening. I think somebody more familliar with the Netgear side of the software will have to advise you on this because Netduma doesn't make this part...
      If it's a problem with the most recent firmware update, you can always downgrade by downloading the previous version from the Netgear support site.
      • Klys's avatar
        Klys
        Tutor
        Regards.
