grdmstr75
Oct 12, 2022Aspirant
Xr500 gaming router - updated FW to latest - connect to Century link C4000bz modem
Hello, I need support to assist in getting this setup. Breakdown: newly installed DSL 80MB century link connection with CL modem model C4000bz , it is powered up and working online Internet DSL c...
- Oct 13, 2022
thanks for the tip , however i was able to get it working now.
i put the Modem which is a CL C4000bz model and the only one they distro now from what i was told by CL.
once i put in bridge mode i left the Vlan tag as 201. CL support told me to put it as 0 which did not work. Once i put in Transparent mode and rebooted my Xr500 router was able to use PPOE to access ISP server. The physical setup is plug eth cable into LAN port 1 on the Modem C4000bz and plug other end to Xr500 WAN port. vohalia - setup creds for PPOE login , did not have to setup VLan tagging either works now.
grdmstr75
as I typed they are worthless - LEVEL 1 support.
Netduma-Liam
Oct 13, 2022NetDuma Partner
Is the modem they've provided you a router/modem combo? Can you please let us know the exact make and model of it? Perhaps we can lookup some guides on it and assist you.
Generally, I'd recommend taking the WAN IP of the XR500 (Found in the DumaOS interface under System Information -> Network status) and putting it in the modem's DMZ. This is generally a more reliable solution than using a bridge/modem mode.
- grdmstr75Oct 13, 2022Aspirant
- FURRYe38Oct 13, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
