Smitty0094
May 06, 2020Tutor
XR500 Gaming Router Lag in Game
Hey, So I just set up this new router with a new modem and I was having large packet loss issues when gaming online. The issue itself was oringally 10-20% packet loss when gaming off my ps4. Tur...
Netduma-Fraser
May 06, 2020NetDuma Partner
What is the average ping you're getting as shown by the Geo-Filter? Are you using Anti-Bufferbloat and Traffic Prioritization on the QoS page? - Those are the options that will help the most with lag.
Smitty0094
May 06, 2020Tutor
I've attached some picture of what i get during a CoD match. This one was peer connected but ping statyed under 50 for the most part.
- Netduma-FraserMay 06, 2020NetDuma PartnerThat is a really good ping, I just checked and it is a server so it's just misclassified as a peer there. What about your QoS settings?
- Smitty0094May 06, 2020Tutor
Thats to QoS of the playstation. Anti-Bufferbloat is set to 70% for both DL and UL and only when high traffic.
- Netduma-FraserMay 07, 2020NetDuma PartnerOkay that is normal. Are you using DumaOS Classified Games or did you add a manual rule? I would suggest following this guide while heavily downloading and changing your Anti-Bufferbloat percentages (while using Always) to see what lowers the ping/keeps it the most stable. That will optimize it for your specific connection. http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping
