DidiChoozRght
Apr 29, 2020Aspirant
XR500 Gaming Router Playstation 4 showing as offline, Newest Firmware 2.3.2.56 no fix?
So I have seen a lot of posts on different forums about this! ( Netgear, Dumos, Reddit ) It has been close to 2 years now. Device offline issues in the device manager software as well as not being mo...
May 07, 2020Guru - Experienced User
You can try sending the FW file over wifi. Just be sure your near the router while sending it.
I recommend getting a USB to ethernet adapter for your macbook air. One thing I miss on new Mac is the LAN port. :smileywink:
DidiChoozRght
May 10, 2020Aspirant
Well... Rolled back the FW and Factory reset. Seemed promissing at first. Started naming devices setting up QOS, antibloat etc.. Slowly started adding in devices it appeared everything was ok. Wifi connecting, recognizing most of the devices. Set static IP for Lan connected PS4. Wireless PS4 Static IP didnt work again, so I deleted that. EX7700 extender connected and is working, but still shows offline. Somewhere in the middle of setting everything up, after I had named most of the devices the router shutdown dropped everything and rebooted. After it came back online and started connecting to everything. The devices I named all showed offline. Everything connected again, all named "Uknown Device" and now there was double the number of devices ( like 50+) in the device manager which sent my QOS distribution crazy. So many devices i couldnt read them. all the online devices showed uknown device. I deleted all the offline devices and logged out. By that time I was pretty upset. Its just wasted time and effort. It looks like its doing the exact same thing. Its a device recognition issue between hardware and what shows up in Device manager.
- FURRYe38May 11, 2020Guru - Experienced User
Well seems like you may have a bad unit, even after downgrading. Something I would return or contact NG support and ask about an RMA.
What version of FW is your EX7700 using?
- DidiChoozRghtMay 12, 2020Aspirant
Not sure what FW Ex7700 is using. It has been showing offline in device manager with both .32 and .56 FW on XR500. I dont ever recall it showing connected ever.. I'm assuming it's most current firmware version because it came inside the XRM570 bundle and the XR500 was preloaded with v2.3.2.56 firmware. And correction to my previous comments, its not "unknown device" its "unnamed device" popping up in device manager. It seems like the device manager is now assigning a new "unnamed device" profile to every mac address when connects. In the .56 version I noticed some device profiles had multiple similar mac addresses ( last four digits were the same), based on how they connect I'm assuming? It seems like the device manager is now creating an "unnamed device" profile for every Mac address. Instead of consolidating similar Mac Id's within one device profile. I don't know, I'm not an IT person but this seems stupid. shouldn't it recognize all the Mac Ids and consolidate them in that one profile? This device recognition seems to be even worse now that I rolled back FW. The newest version v2.3.2.56 seemed to be consolidating Mac IDs better after it was running for awhile... I don't know, I might try to upgrade FW back to .56 and do a factory rest again... Does what I'm saying about Mac addresses make sense? Again I'm no IT person... Any more Ideas?
- FURRYe38May 12, 2020Guru - Experienced User
Seems the the FW is not getting or acquiring correct device mfr model information from the devices via ARP process, thus setting up unnamed device in the UI.
Log into the EX7700 and you can find out what version of FW is loaded on it.
- Netduma-FraserMay 12, 2020NetDuma PartnerSorry to hear this is still an issue. Could you try putting the EX in AP mode and then enabling the one wifi name feature to make it the same as the XR and then see if devices appear online correctly?
- DidiChoozRghtMay 13, 2020Aspirant
FURRYe38 wrote:Seems the the FW is not getting or acquiring correct device mfr model information from the devices via ARP process, thus setting up unnamed device in the UI.
So the ARP process issue.. Thats gonna be a Firmware issue? It is more of an issue now that I downgraded to v.32 but it was still somewhat present in the originaly loaded v.56. I think that had something to do with my original problem. Im going to upgrade back to v.56 and factory reset again when I get a chance to see if I can stop this madness.
Question... How would/could the hardware be affecting the ARP process? should I replace this unit?
Netduma-Fraser wrote:
Could you try putting the EX in AP mode and then enabling the one wifi name feature to make it the same as the XR and then see if devices appear online correctly?I think it is in the one wifi name mode from startup if i'm not mistaken. It is the XRM570 mesh bundle. The setup process has you power it up and link to XR500 before you change factory password so it pushes to the extender. Also to put it in AP mode doesn't it have to be wired to the router? That kind of defeats the purpose of me having a wireless extender on the other side of my the house if I have to Lan cable it to the router. It recognized the extender at first because the offline device says EX7700. And it appears to be working because all the lights are light up on it.. I think it all has to do with the same Device manager issues that all these other threads are reporting...
How is the Device Manager issue going to get fixed in the next version v3.0, if you don't know whats wrong with it?
Checkout the unnamed devices in the pic! Uuuuuggggghhhhh.
- Netduma-FraserMay 13, 2020NetDuma PartnerI get that, if you could put it into AP mode and it works then we can put it down to the specific repeater mode that is causing the issue which will then allow us to reproduce the issue and resolve it. We have an EX so we can investigate. We are making general optimizations to DM regardless as we can see this in other scenarios.
I get that, if you could put it into AP mode and it works then we can put it down to the specific repeater mode that is causing the issue which will then allow us to reproduce the issue and resolve it. We have an EX so we can investigate.I'll see if I can mess with it this weekend. I updated FW back to v.56 and did factory rest. I setup network again and basic settings for QOS, GEO filter, and a static IP for Wired PS4 this morning. That was about all I had time for. I will let it run for a couple days. I dont have a lot of time, paitence, and/or desire to mess with it right now. I'll see what it looks like when I log in this weekend and decide how much more time I want to put into it...
- FURRYe38May 14, 2020Guru - Experienced User
Be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
- Netduma-FraserMay 14, 2020NetDuma PartnerTotally understand that, let us know when you can and we can go from there.
