zonum6
Mar 25, 2019Guide
XR500 Gaming Router Playstation 4 showing as offline
Hello All,
I have seen some post regarding this issue. One of the solutions was to reboot the router. This does work, however, I end up rebooting my router at least once a day. This only start...
- Mar 26, 2019I believe the team are aware, if you downgrade to .32 do you still see the issue?
Mar 25, 2019Guru - Experienced User
What FW is currently loaded?
How is the PS connected to the router? Wired or wireless?
Set a reserved IP address ON the router for the PS?
- zonum6Mar 25, 2019Guide
Hi and thanks for the reply.
The firmware is 2.3.2.40
I own the cable modem and it is a zoom cable modem 3.0
I have 2 ps4's and both are hardwired. One goes through a switch and the other is connected directly to the router. Both have the same behavior.
I did set a static IP on one of the ps4's but it did not make a difference.
- FURRYe38Mar 25, 2019Guru - Experienced User
Does the modem have a built in router?
Remove the static IP address from the PS.
Set RESERVED IP addresses for the PS consoles ON the router.
What is the mfr and model of the switch your using?
Do the game consoles connect to the internet and the gaming services ok?
No it's just a modem.
The switch is a Nighthawk 8000.
I'll try the reservation and let you know.
The gaming services work fine but I don't get any of the anti-bufferbloat, QoS, or geo filter settings.
