zonum6
Mar 25, 2019Guide
XR500 Gaming Router Playstation 4 showing as offline
Hello All,
I have seen some post regarding this issue. One of the solutions was to reboot the router. This does work, however, I end up rebooting my router at least once a day. This only start...
- Mar 26, 2019I believe the team are aware, if you downgrade to .32 do you still see the issue?
zonum6
Mar 25, 2019Guide
No it's just a modem.
The switch is a Nighthawk 8000.
I'll try the reservation and let you know.
The gaming services work fine but I don't get any of the anti-bufferbloat, QoS, or geo filter settings.
Mar 26, 2019Guru - Experienced User
Also try with out the NG switch in the mix as well to see if there is any differences.
- Netduma-FraserMar 26, 2019NetDuma PartnerI believe the team are aware, if you downgrade to .32 do you still see the issue?
