zonum6
Mar 25, 2019Guide
XR500 Gaming Router Playstation 4 showing as offline
Hello All,
I have seen some post regarding this issue. One of the solutions was to reboot the router. This does work, however, I end up rebooting my router at least once a day. This only start...
- Mar 26, 2019I believe the team are aware, if you downgrade to .32 do you still see the issue?
Mar 26, 2019Guru - Experienced User
Also try with out the NG switch in the mix as well to see if there is any differences.
Netduma-Fraser
Mar 26, 2019NetDuma Partner
