ConcreteSlayr
Nov 25, 2019Tutor
XR500 Geo-Filter False Location
Ever since I started playing Modern Warfare 2019 I have a dedicated server continuously showing up on the other side of the US. I live in Southeast US. When i log into Modern Warfare like normal all ...
Netduma_Alex
Nov 26, 2019NetDuma Partner
This server that doesn't go away on the map, does it have a white ring around it? If it does, this means that it is an authentication server and is required in order for the game to function.
If not it doesn't have a white ring, it might be what the game thinks is the best server for you to connect to, although this doesn't make much sense given it's at the opposite side of the country...
If you put the Geo-Filter into Spectating Mode, does the game still stick with the same server?
ConcreteSlayr
Nov 27, 2019Tutor
sometimes it has a dotted circle around it (usually when i have ping assist set at anything but 0). Sometimes it is just a square showing its a dedicated server. I dont think i have seen a solid circle.I attached a pic of my geofilter. The peer is a friend in party chat. The one in Oregon is always there and the one in Europe is there off and on. My friend being in party chat has no affect . Those servers constantly are showing up. In BO4 the EU one was there sometimes but the oregon one is only Modern Warfare
- Netduma-FraserNov 28, 2019NetDuma PartnerIt actually looks like you're not filtering at all. Do you have the device set to Filtering Mode as it looks as though it may be set to Spectating Mode.
