scho3
Nov 28, 2022Aspirant
XR500 Geo Filter Issues
I am having an odd issue with the Geo Filter not working for COD MW2/WZ2 on PC. I attempted to set the device as a PC, Console, and Playstation in device manager and selected the title from the list a...
Netduma-Fraser
Nov 28, 2022NetDuma Partner
Check your IP on the PC itself, then check that the device you think it is on the Device Manager has the same IP address, if it's not you'll need to select the correct device, then it will work on the Geo-Filter.
- scho3Nov 28, 2022AspirantThanks for the response, but I have my gaming PC setup with a reserved IP address so it should always be the same IP.
- Netduma-LiamNov 29, 2022NetDuma Partner
It's worth double checking to be sure.
Does you PC have another ethernet or Wi-Fi adapter that could be connected to a different network? For example, is it still connected to your ISP equipment's Wi-Fi?
