alwong26
Dec 20, 2022Aspirant
xr500 geo filter wont load up.
xr500 geo filter wont load up. and neither will my ping heatmap i keep getting the rapp and a uncaught and undefined error message. ive reboot and factor reset and still the samething can anyone hel...
Netduma-Fraser
Dec 20, 2022NetDuma Partner
Download the DumaOS app for your mobile from the app store, then access the QoS & Geo-Filter pages and remove any devices that appear there. Then you should be able to access on PC without issue.
alwong26
i did as you posted and still the samething.
