alwong26
Dec 20, 2022Aspirant
xr500 geo filter wont load up.
xr500 geo filter wont load up. and neither will my ping heatmap i keep getting the rapp and a uncaught and undefined error message. ive reboot and factor reset and still the samething can anyone hel...
alwong26
i keep getting these two message and the loading circle
Netduma-Fraser
Dec 22, 2022NetDuma Partner
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
- PBR_SteveFeb 20, 2023Aspirant
did what was mentioned above and still does not work fact reset doesnt fix either
- Netduma-LiamFeb 20, 2023NetDuma Partner
Since doing that can you clear your browser's cache and see if you're still getting the same problem?
- PBR_SteveMar 25, 2023Aspirant
Rapp not loading the issue still exists in 2023 mobile wont work either all mentioned instructions do not fix the issue ive tried diff browsers cache clear factory rests in all ways possible , button reset , power down reset , retries 3 -5 a new update needs to fix the bug all devices are current i cant manage anything zero app control functions work.
