alwong26
Dec 20, 2022Aspirant
xr500 geo filter wont load up.
xr500 geo filter wont load up. and neither will my ping heatmap i keep getting the rapp and a uncaught and undefined error message. ive reboot and factor reset and still the samething can anyone hel...
Netduma-Liam
Feb 20, 2023NetDuma Partner
Since doing that can you clear your browser's cache and see if you're still getting the same problem?
PBR_Steve
Mar 25, 2023Aspirant
Rapp not loading the issue still exists in 2023 mobile wont work either all mentioned instructions do not fix the issue ive tried diff browsers cache clear factory rests in all ways possible , button reset , power down reset , retries 3 -5 a new update needs to fix the bug all devices are current i cant manage anything zero app control functions work.
- Netduma-FraserMar 25, 2023NetDuma PartnerMake an account on forum.netduma.com and let us know your username, we can then give you access to the beta.
- PBR_SteveApr 28, 2023Aspirant
PBR_steve is my account name.
- Netduma-FraserApr 29, 2023NetDuma PartnerAdded, head over to the forum and you'll see the Nighthawk Pro Gaming Beta sub forum
