GamerDuDe
Feb 17, 2020Guide
Xr500 Geofilter crashing google chrome
As title says. Last night I denied some server and now it just crasges everytime I try to open it. If I go to a dmin etc it works fine its just as soon as the geo filter comes into view it crashes
Netduma_Alex
Feb 18, 2020NetDuma Partner
So the browser actually stops responding when Geo-Filter is loading?
- GamerDuDeFeb 18, 2020GuideYeah..... as soon as the geo filter comes up everything atops. I have to shut down chrome and start up again just to get it to work. Doesn't happen on anything else!
- Netduma-FraserFeb 18, 2020NetDuma PartnerThat is really strange, when the page stops responding could you right click on the page and go to Inspect Element > Console tab on the window that appears and take a screenshot please? That will help us determine what caused the issue, you should be able to either reboot or reset the router to fix the issue.
- GamerDuDeFeb 18, 2020GuideWhen I get home. I will be only be able to do it on my phone. Will that make a difference?
