GamerDuDe
Feb 17, 2020Guide
Xr500 Geofilter crashing google chrome
As title says. Last night I denied some server and now it just crasges everytime I try to open it. If I go to a dmin etc it works fine its just as soon as the geo filter comes into view it crashes
GamerDuDe
Feb 18, 2020Guide
Yeah..... as soon as the geo filter comes up everything atops. I have to shut down chrome and start up again just to get it to work. Doesn't happen on anything else!
Netduma-Fraser
Feb 18, 2020NetDuma Partner
That is really strange, when the page stops responding could you right click on the page and go to Inspect Element > Console tab on the window that appears and take a screenshot please? That will help us determine what caused the issue, you should be able to either reboot or reset the router to fix the issue.
- GamerDuDeFeb 18, 2020GuideWhen I get home. I will be only be able to do it on my phone. Will that make a difference?
- Netduma-FraserFeb 18, 2020NetDuma PartnerProbably won't be possible to do it on your phone, do you not have a PC at all? The interface isn't optimised for mobile browsers either so that might be the issue itself. If it was fine before hand then do the reboot/reset instead.
- GamerDuDeFeb 18, 2020GuideNo pc anymore. There is a way to view source on a chrome browser just not sure if I will be able to access it because it completely freezes everythi.g up. Ive had the router for a yr now and this is the first time ive experienced this
