ClockWork_Doc
Feb 04, 2019Aspirant
XR500 Geofilter not populating PC Unreal Engine (Fortnite) servers; Ping remains elevated
I bought the Nighthawk XR500 in order to manage my In-Home connectivity and reduce my ping. I've been victim to chronic and variable ping spikes that directly impacts my in-game performance & streami...
Netduma_Jack
Feb 05, 2019NetDuma Partner
Hi there,
Can you actually see the servers on your Geo-Filter? Or not at all?
If not, could you delete any devices you added to the GEo-Filter. Then go to the device manager, click on your PC and change the device type to a Playstation (I appreciate you may have already done this). Then go back to the Geo-Filter, and add your PC to the top again. It should now populate.
As for pings, both are solid, but if I were you I would try just playing on the server that you feel plays the best, regardless of where it's located. Of course, this is usually the server with the lowest ping.
If you want to invesitgate the route your packets are taking to a Fortnite dedicated server, you could try installing PingPlotter on your PC and then set a Fortnite server as the target. It's possible your ISP is using a weird route. There's a guide to using PingPlotter here: http://forum.netduma.com/topic/23881-ping-plotter-quick-guide/
Finally, I would also follow that guide just to run a simple line test on your network to see if you're suffering from any line quality issues.
