Marv-K
Feb 05, 2023Guide
XR500 Geofilter Problem Ps5
Hallo ich habe eine Frage bzw ein Problem. Ich nutze VPN (keepsolid open vpn) und den Geofilter . Aber ich finde ohne Crossplay keine Spiele.Natürlich habe ich den Geofilter richtig eingestellt . Habe...
- Feb 07, 2023If you could just join a game as a test then take the screenshot that would indicate what is happening. It's hard to say without seeing exactly what is happening, it could be a server is incorrectly whitelisted for example which we could fix with a cloud update
Netduma-Fraser
Feb 05, 2023NetDuma Partner
Without the VPN do this to try for New York.Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works better.
Wait 2 minutes
Marv-K
Feb 06, 2023Guide
I've tried that many times. As soon as I only use the geofilter it doesn't work at all. The ping doesn't change there and I find the same lobbies as without the geofilter. Very annoying, unfortunately..
- Netduma-FraserFeb 06, 2023NetDuma PartnerCan you provide a screenshot of the Geo-Filter page when you're getting the same games as usual? What do you mean 3 PlayStation options?
- Marv-KFeb 06, 2023Guide
When I start the game, the servers are displayed on the geofilter for a few seconds, but then they disappear again immediately. And I also don't ping any server in this circle (North America) because I have the same ping as when I disabled Geofilter and VPN. Of course, I also activate the filter before the game starts and select the region. I'm doing everything right and I've tried everything. But it doesn't work.
- Netduma-FraserFeb 06, 2023NetDuma PartnerYou need to set Ping Assist to 0 to force servers within a specific radius, you also haven't set your location/radius to cover the US which you will need to do
