Marv-K
Feb 05, 2023Guide
XR500 Geofilter Problem Ps5
Hallo ich habe eine Frage bzw ein Problem. Ich nutze VPN (keepsolid open vpn) und den Geofilter . Aber ich finde ohne Crossplay keine Spiele.Natürlich habe ich den Geofilter richtig eingestellt . Habe...
- Feb 07, 2023If you could just join a game as a test then take the screenshot that would indicate what is happening. It's hard to say without seeing exactly what is happening, it could be a server is incorrectly whitelisted for example which we could fix with a cloud update
Marv-K
Feb 07, 2023Guide
I normally have a ping of 35 ms, without geofilter without vpn. Absolutely normal. When I turn on the geofilter and select the USA region, the ping doesn't change when I search for games. As if the Geofilter would not react or not work. It's difficult to show, because I'm in the Netduma settings on my laptop and I'm playing with the PS5. Is it possible that the Geofilter on the XR500 is not working properly?
Netduma-Fraser
Feb 07, 2023NetDuma Partner
- Marv-KFeb 11, 2023GuideI think I partially solved the problem. But I have another question, can I actually only join dedicated servers with the geofilter? Or is it also possible to change that so that I can also find normal servers in the selected region?
- Netduma-FraserFeb 11, 2023NetDuma PartnerWhatever matchmaking system uses, dedicated servers or peer hosts or a hybrid of the two you can connect to. Most games these days do use dedicated servers.
