Nate808365
Mar 20, 2018Aspirant
XR500 geofilter question
I live in hawaii, had a question with mapping the circle . Should i map the circle on the hawaiian islands and spread it out to hit cali servers or can i just put the circle anywhere? I noticed when i...
- Mar 20, 2018
Hi Nate,
Personally I would say this is all down to preference. 23ms sounds like a fantastic ping to play on - generally speaking, the lower your ping, the better your gameplay will be. If you're able to secure hosts with such a low ping easily then I would recommend keeping the Geo-Filter set up how you had it! Local servers aren't always the best ones, so don't worry if they are on mainland America.
Headquarters relies on dedicated servers rather than peer-to-peer, so with strict mode on it's likely that you're blocking servers necessary to connect. It likely forces the game to attempt to connect you to another server within your radius, eventually letting you join. I'm glad you can connect easily without strict mode enabled :)
Nate808365
Mar 21, 2018Aspirant
Thanks, my main concern was just picking where the home circle. When i pit it on the mainland servers my friends from hawaii cant connect to me, even in party chat. The radius would have to be within hawaii the spreaded out.
Netduma_Jack
Mar 21, 2018NetDuma Partner
In that case you need to add your friends to the Allow list. Invite them into a private game (so their icons are the only ones on the Geo-Filter map). Then open their Ping panels and click 'Allow'. This will ensure that even when they are exluded from the radius they can still connect to you.
I hope this helps!
- Nate808365Mar 21, 2018AspirantThanks
