SonnyLewisDmnd
May 02, 2018Guide
Xr500 geofilter/ping question ww2 ps4
Hi all,I’m currently in Melbourne Australia and COD ww2 dedicated server is located in Sydney approximately 900km away my question is if I was to manually ping players on geo map should I deny player...
Netduma-Fraser
May 02, 2018NetDuma Partner
You can't influence others connections like that, it's impossible unfortunately. I feel like there may be 2, there used to be with previous CoD titles. Move your home location to a position where you can expand your radius to cover all of Australia but block out Sydney to check.
If servers go down for any reason it would switch over to P2P but servers are the majority of matchmaking.
SonnyLewisDmnd
May 02, 2018Guide
Ok I’ll experiment that option as I haven’t tried that yet I was just assuming there was only the 1 server in Sydney,thanks again
