Neowolf
Dec 28, 2021Initiate
Xr500 Good signal, bad connection
Hi, I Have a good signal at my bed room but the connection is really bad. If i go closer to the router the connection are fixed. In the beginning work perfectly, but now start work fine like a minut...
- Dec 29, 2021
I use smart connect, I try without smartconnect to check if the problem is resolved with this.
Netduma-Fraser
Dec 28, 2021NetDuma Partner
Are you using Smart Connect for WiFi or connecting to 2.4/5GHz manually? It may be that there are more WiFi networks in your area now and so it may be beneficial to use a WiFi analyzer to find the least congested channel and change to that.
- NeowolfDec 29, 2021Initiate
