Neowolf's avatar
Neowolf
Initiate
Dec 28, 2021
Xr500 Good signal, bad connection
Hi, I Have a good signal at my bed room but the connection is really bad. If i go closer to the router the connection are fixed. In the beginning work perfectly, but now start work fine like a minut...
  • Neowolf's avatar
    Neowolf
    Dec 29, 2021
    I use smart connect, I try without smartconnect to check if the problem is resolved with this.
