mncomputerguy
Sep 10, 2018Tutor
XR500 Halo 5 party question
In Halo 5 with geofiltering enabled, my doubles partner once in a while ends up in a game without me since the router drops the connection to a server outside of the geofilters range. I have the xr5...
Netduma-Fraser
Sep 10, 2018NetDuma Partner
Are you the party leader? You should be if you're using the Geo-Filter. If you are then usually the game should drop you both out, if its not doing that then theres no way that I know of unfortunately. Just an annoying game mechanic.
mncomputerguy
Sep 10, 2018Tutor
Excellent thanks for the heads up, not sure if I was party leader or not as we tend to go back and forth on that. Will give it a shot next couple of times we play and see if it makes a difference.
