DmyTgregu
Jan 22, 2018Aspirant
XR500 hardware seems identical to R7800
The r7800 seems to have the same hardware specs as the newly announced XR500 pro gaming router. Which makes me wonder, will the DumaOS firmware be available to us who recently bought the R7800 as a ga...
BretD
Jan 25, 2018Administrator
Thanks for your interest in the Nighthawk Pro Gaming XR500. Router. Although the base hardware specs seem similar, there are particulars of the hardware platform that means any sort of "Porting" of the OS from one device to another is not so cut and dry.
- DmyTgreguJan 26, 2018AspirantThanks for your reply. I understand that the hardware isn’t identical, just that it seems more than capable of running the OS if tweaked. I only ask because I still experience some bufferbloat when someone is streaming video while I’m gaming. It’s much better than with dynamic qos off, but the latency variation isn’t rock solid. I wonder if the next generation cake qos could perhaps be implemented instead. It’s just somewhat frustrating that soon after a gaming router is purchased a very similar one with “better gaming firmware” is released. I know there are custom firmware options out there but then you lose some of the stability and general WiFi features that the rest of the non-gamers in the home rely on. Just wish the qos was a bit better. Thanks
- FURRYe38Jan 30, 2018Guru - Experienced User
Have you tried Voxels FW for the R7800?
- DmyTgreguJan 30, 2018AspirantNo I haven’t tried any custom firmware. I heard openwrt LEDE has the next gen qos but I was afraid of losing MUMIMO and other niceties. I heard Voxel’s is much closer to stock so you don’t lose those features but I wasn’t sure how much of an improvement that firmware was for qos.
