Robh19
Jan 17, 2019Aspirant
XR500 Hardwire console procedure
I set my router up last night, but i can’t figure out how to run it with a wired connection to my consoles. Called tech support today and was told that I had to pay an additional $159.99 to download a...
Jan 17, 2019Guru - Experienced User
game consoles?
Just connect a CAT6 LAN cable between the router and the game consoles.
Netduma-Fraser
Jan 17, 2019NetDuma Partner
As above. Also if you purchased the router new you'll need to register it and then you should be able to contact tech support without paying anything
