Robh19
Jan 17, 2019Aspirant
XR500 Hardwire console procedure
I set my router up last night, but i can’t figure out how to run it with a wired connection to my consoles. Called tech support today and was told that I had to pay an additional $159.99 to download a...
Netduma-Fraser
Jan 18, 2019NetDuma Partner
Are you referring to the Device Manager? It may not have detected what it was but should still appear, just may need to rename the device. Match the IP/MAC address shown on the Device Manager with the console network settings. Are you using the Geo-Filter?
Robh19
Jan 18, 2019Aspirant
Yes, I’m using the geo filter.
