Lejeunez
Sep 22, 2020Tutor
Xr500 Hardwire high latency and NAT
Hi! So I just switched from charter spectrum to a new internet provider that is supposed to be like fiber called Great Lakes energy Truestream. I reinstalled the router hardwired to Xbox but when I tr...
Lejeunez
Sep 22, 2020Tutor
Also, this is a picture I just took of the speeds testing the router on the app.
- Netduma-FraserSep 23, 2020NetDuma PartnerFirst of all, do you have a pure modem or a router that gives WiFi from your new provider? If the latter how have you connected the XR to it to ensure an open NAT? e.g. modem, bridge mode, DMZ etc.
- LejeunezSep 23, 2020TutorIt should be a pure modem, they had the WiFi option but because I had this router they said it was better than anything they used.
- Netduma-FraserSep 23, 2020NetDuma PartnerWhat do you mean they had the WiFi option? Do you mean the modem you have right now is capable of WiFi or they would have given you a router with WiFi if you didn't have the XR? On the XR in WAN Settings change NAT to Open, does that help with the NAT issue?
