Vantharas
May 14, 2020Follower
XR500 Has reduced Bandwidth by half?
I just bought a new XR500. Plugged it up, hooked everything up. Used the quickstart guide, I renamed my wifi networks ( So I have two seperate names for my 5ghz and 2.4ghz ) Except now if I plug...
Netduma-Fraser
May 16, 2020NetDuma Partner
How did you disable QoS, by selecting the option in the Anti-Bufferbloat settings menu? Sometimes with a new router it can take a little while to sync with the ISP modem. You can speed this up by setting the router MAC address to the previous router MAC address in Internet Setup.
