ExZachly
Jan 10, 2021Follower
XR500 High Ping Under Load (Connection benchmark)
I've been getting high ping under load during upload (400ms+) .... So last night I disabled port scan / dos protection and I also enabled respond to internet ping and I finally got an A+ score (24ms)...
Netduma-Fraser
Jan 11, 2021NetDuma Partner
At the moment the graph is reporting higher than expected so we will be fixing that. I'd suggest adjusting the sliders manually to find what works best for you, you won't have actually had that ping if your connection was under load.
