jrwalte
Jun 14, 2021Aspirant
XR500 horrible local wifi performance
I have an issue on my network I can't figure out. It started with having issues streaming local media content from an Emby server to wifi clients. Anything above 5mbps would have constant freezing. I...
jrwalte
The server is wired. I can achieve 95MBps on a wired file transfer test. It's running Server 2012.
I'll try the firmware update and reset.
Netduma-Liam
Jun 14, 2021NetDuma Partner
OK sure thing, thanks for letting us know.
Keep us updated with how you get on after the firmware upgrade.
- jrwalteJun 14, 2021Aspirant
So I am worse off than when I started. After updating beta firmware and resetting the network, my wifi performance remained the same while my wired performance dropped from 95MBps to 70MBps. I turned QoS features off in case that was throttling it and there was no change.
How long has this bug been known? Is there anything else to try? I'm concerned this will never get fixed. In which case, I need to throw Netgear in the trash and never look back.
- Netduma-LiamJun 15, 2021NetDuma Partner
Sorry to hear that, I don't see how an upgrade could've caused that but if you continue to have these issues you can always re-install the full release firmware.
This issue hasn't been too common - at least on DumaOS powered routers so I'm not sure exactly how close to a fix Netgear are. You could always open a ticket with them directly at support.netgear.com and report the bug directly to them.
