jncash3
Apr 10, 2020Follower
XR500 how to enable ipv6 on the local computer
Any suggestions on how to enable Ipv6, I downloaded the instructions on the XR router which was straight forward. But I am missing something. (note trying to connect to meta agent software to conne...
Netduma-Fraser
Apr 14, 2020NetDuma Partner
So you've enabled IPv6 in Settings > Advanced Settings > IPv6? If so then this gives you the option to enable DHCP so it can give IPv6 addresses to LAN devices so shouldn't be necessary to apply on the device itself. If it is necessary then option 2 on this guide shows you how https://www.tenforums.com/tutorials/90033-enable-disable-ipv6-windows.html
