fedupofmyXR500
Oct 26, 2022Aspirant
XR500 how to schedule a daily reboot or a DHCP renewal ?
Hello, My XR500 looses my ISP gateway, DNS and DHCP server almost every 24 hours. The result is a loss of internet connection. I have two ways to reconnect : 1) in DumasOS menu, i go to Sett...
fedupofmyXR500
Oct 27, 2022Aspirant
I disabled the DHCP server on XR500 and enabled it on the Wifi Access Point.
I'll let you know if it has solved the daily internet disconnection problem. If not, that means XR500's DHCP server is not involved in this problem.
Netduma-Fraser
Oct 27, 2022NetDuma Partner
I would suggest you set a Static WAN IP on the Internet Setup page as well, just in case, keep us posted!
- fedupofmyXR500Oct 27, 2022Aspirant
Hello,
I can't set a static IP address for WAN. Unfortunately, i have to pay for it đ
- Netduma-FraserOct 27, 2022NetDuma PartnerDo you know how long your public IP lease is? It may coincide with that, in which case I'd recommend calling them and asking them to extend it to a 7 day lease and see if that resolves it.
