fedupofmyXR500
Oct 26, 2022Aspirant
XR500 how to schedule a daily reboot or a DHCP renewal ?
Hello, My XR500 looses my ISP gateway, DNS and DHCP server almost every 24 hours. The result is a loss of internet connection. I have two ways to reconnect : 1) in DumasOS menu, i go to Sett...
fedupofmyXR500
Oct 27, 2022Aspirant
After a few more tests, The XR500's DHCP server has to be enabled. If not ==> No TV ...
Netduma-Fraser
Oct 27, 2022NetDuma Partner
You'll have to give the TV a reserved IP address, then it can connect with DHCP disabled
- fedupofmyXR500Oct 28, 2022Aspirant
Hello,
It doesn't work. The TV Box needs DHCP. So i can't get rid of DHCP server on XR500.
- Netduma-LiamOct 28, 2022NetDuma Partner
That seems bizarre, the TV likely won't have any knowledge of the method by which it's received it's IP address, but I guess you can still try leaving that as the only device without a static IP and hope it works still.
- FURRYe38Oct 28, 2022Guru - Experienced User
"I already set up a DHCP range from 192.168.1.100 to 192.168.1.200 for devices configured in DHCP mode." Then that's should be all that's needed. Let the TV and other devices dynamically connect with in this IP address pool range. Router should work with this.. I know my XR450 and XR1000 do.
- fedupofmyXR500Oct 29, 2022Aspirant
Hello,
Well, i'm back to the starting point. Loss of gateway and DNS from my ISP.
I was wondering if i can set a static route to their servers. But if my Wan IP changes, i guess my gateway will change too... so it can't be a solution.I will look at the gateway and DNS addresses when my WAN IP will be renewed. It can take a few weeks... If they are still the same, i'll try to set a static route.
- Netduma-FraserOct 29, 2022NetDuma PartnerKeep us posted! It would likely be easier to call the ISP and get them to extend the lease time though
- FURRYe38Oct 30, 2022Guru - Experienced User
- fedupofmyXR500Nov 03, 2022Aspirant
It is a Huawei EchoLife HG8010a
- FURRYe38Nov 10, 2022Guru - Experienced User
Have the ISP check the signal and line quality UP to the ONT. Possible there could be some odd behavior between the ISP and ONT as well.
Be sure to set the XR router for .100 to .200 IP address pool range.Be sure to use CAT6 lan cable between the ONT and XR router.
