Mstewart87
Dec 18, 2018Aspirant
XR500 Hybrid VPN advanced Setup IPvanish
i am trying to setup the advanced settings for Hybrid VPN and it seems as if it will only accept a text input. the config file i recieved from my VPN is a zip file containing the security certifica...
Netduma-Fraser
Dec 19, 2018NetDuma Partner
Although this is an old article for our previous software (not DumaOS) the same applies and should help you here: http://support.netduma.com/en/support/solutions/articles/16000027547-using-the-vpn-feature-with-a-non-supported-vpn-provider
