Marc_Marc
Feb 27, 2019Apprentice
XR500 Hybrid VPN Torguard DNS leak
I am having trouble preventing the DNS from leaking in my hybrid VPN setup.
I have added the following lines to my VPN confing but they dont help.
push "block-outside-dns" push "dhcp-option DN...
ShadowYoda
Apr 17, 2019Aspirant
Hi I just wanted to add that I am having this same issue on my desktop. I have tried adding the settings as well to my configuration and they did not work. I also tried routing my dns requests to cloudflare servers but I still get dns leaks. If I use the desktop app made by expressVpn the dns leaks go away. Let me know if there is more info I can give to help out, I have been waiting on this firmware update for a while :D.
- Marc_MarcApr 18, 2019ApprenticeShadowYoda, I have been waiting for the firmware update for a while as well doesn't seem like it's coming but I found 2 work arounds for the problem both involve dd-wrt.
1. This is the method I use and recommend. Take your old router flash dd-wrt on it. You can pretty much do everything on dd-wrt that you can do on the Xr500. If you have used dd-wrt before I am sure you know. You can use ip routing to select which devices should use the VPN and which ones don't. You have to assign the devices a static ip on dd-wrt. All this is really easy to do and takes 15 mins. In addition if you want to use the xr500 just run an Ethernet cable from your Modem to the xr500 in port and then one out to your old dd-wrt router with the VPN on it. Now you have the gaming goodness of the xr500 and the VPN on your old one. You can even manage how much bandwidth your VPN devices can use through netduma. Just connect the devices you want on VPN to the old router and the gaming console to your xr500. Best of both worlds :p
In case you don't have your old router anymore just buy the r6400 it's a cheap ($26) excellent router with great range and plays well with Dd-wrt.
https://www.amazon.com/Netgear-R6400-AC1750-Router-R6400-100NAS/dp/B078LL23M1/ref=mp_s_a_1_4?keywords=R6400&qid=1555603965&s=gateway&sr=8-4
The dd-wrt firmware ftp just find your router.
https://download1.dd-wrt.com/dd-wrtv2/downloads/betas/2019/04-16-2019-r39538/
2. Flash dd-wrt on your XR500, you can pretty much do everything on dd-wrt that you can do on the Xr500.- Netduma-FraserApr 18, 2019NetDuma PartnerThanks Shadow for letting us know you're having the issue as well, as Jack mentioned the team were working on a fix so I'm confident this will be resolved in a future firmware and unfortunately we don't determine when a firmware is released.
