bozzman
Dec 08, 2020Aspirant
XR500, I can't get an Mitel IP Phone to work with the Router
Hi guys I have a Netgear XR500 Gaming Router, the problem I'm having is I hooked a Mitel 5320e IP phone to the router so my wife could work from home. The phone says it's "searching for the Server" b...
Dec 08, 2020Guru - Experienced User
What modem/gateway do you have?
that can be key. If its a combo device, it can cause a double nat and the phone might not work with double nats well.
bozzman
Hi thanks for the reply, the modem is a Spectrum Brand as they are also the ISP and no it's not a combo device.
- plemansDec 09, 2020Guru - Experienced User
it sure could be a modem only. tough to tell without a model though.
try this:
- Netduma-FraserDec 09, 2020NetDuma PartnerToggle SIP ALG and IGMP Proxying in WAN Settings, also switch NAT to Open. If that doesn't help disable QoS entirely from the 3 line option menu in Anti-Bufferbloat on the QoS page and see if it works.
- bozzmanDec 10, 2020AspirantHi I tried everything but still no luck yet, thanks
- Netduma-FraserDec 13, 2020NetDuma PartnerTry upgrading to the beta and then use Traffic Controller to allow ALL traffic to the phone.
